Lo que pasa por chulear con un dodge Ram
<object width="450" height="370"><param name="movie" value="http://www.liveleak.com/e/1fb_1254203344"></param><param name="wmode" value="transparent"></param><embed src="http://www.liveleak.com/e/1fb_1254203344&quot; type="application/x-shockwave-flash" wmode="transparent" width="450" height="370"></embed></object>
