Inicio Off-Topics
Me da igual
A quien le importa lo que yo haga,a quien le importa lo que yo diga.
Yo soy asi y asi seguire nunca cambiare.
  • WarpauWarpau Forero Master
    +1
    diezcaracteres
    Aviones y coches , ay que cosicas mas ricas!!! <img src="https://us.v-cdn.net/6030826/uploads/emojis/15.gif"/&gt;
  • And now, the end is near;
    And so I face the final curtain.
    My friend, Ill say it clear,
    Ill state my case, of which Im certain.
    Ive lived a life thats full.
    Ive traveled each and evry highway;
    And more, much more than this,
    I did it my way.
    Regrets, Ive had a few;
    But then again, too few to mention.
    I did what I had to do
    And saw it through without exemption.
    I planned each charted course;
    Each careful step along the byway,
    But more, much more than this,
    I did it my way.
    Yes, there were times, Im sure you knew
    When I bit off more than I could chew.
    But through it all, when there was doubt,
    I ate it up and spit it out.
    I faced it all and I stood tall;
    And did it my way.
    Ive loved, Ive laughed and cried.
    Ive had my fill; my share of losing.
    And now, as tears subside,
    I find it all so amusing.
    To think I did all that;
    And may I say - not in a shy way,
    No, oh no not me,
    I did it my way.
    For what is a man, what has he got?
    If not himself, then he has naught.
    To say the things he truly feels;
    And not the words of one who kneels.
    The record shows I took the blows -
    And did it my way!
  • [FONT=arial,tahoma,verdana]El final, se acerca ya,lo esperaré, serenamente,ya ves, que yo he sido así,te lo diré, sinceramente,viví, la inmensidad,sin conocer, jamás fronterasy bien, sin descansar, y a mi manera.Jamás, tuve un amor,que para mí, fuera importante,tomé, solo la flor,y lo mejor, de cada instante,vviv, y disfruté,no sé si más, que otro cualquiera,y si, todo esto fué, ami manera.Por que sabrás, que un hombre al fin,conocerás por su vivir,no hay por que hablar, ni que decir,ni que llorar ni que fingir,puedo seguir, hasta el final,a mi manera.Tal vez lloré, o tal vez reí,tal vea gané, o tal vez perdí,ahora sé que fuí feliz,que si lloré, también amé,puedo vivr, hasta el final, ami manera.[/FONT]</PRE>
  • GirasolGirasol MegaForero ✭✭✭
    Que suene la música...
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/lxl_-wYSxt8&hl=es&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/lxl_-wYSxt8&hl=es&fs=1&quot; type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
    "Primero vinieron por los comunistas y no dije nada porque yo no era comunista.
    Luego vinieron por los judíos y no dije nada porque yo no era judío.
    Luego vinieron por los sindicalistas y no dije nada porque yo no era sindicalista.
    Luego vinieron por los católicos y no dije nada porque yo era protestante.
    Luego vinieron por mí, pero para entonces ya no quedaba nadie que dijera nada".
    Martin Niemöller, (1938).
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/t6Lp4w8wyy0&hl=es&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/t6Lp4w8wyy0&hl=es&fs=1&quot; type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
  • .Tal vez lloré, o tal vez reí,tal vea gané, o tal vez perdí,ahora sé que fuí feliz,que si lloré, también amé,puedo vivr, hasta el final, ami manera.
  • Y a bailaaaarrrrr
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/s8gTpMdAj_k&hl=es&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/s8gTpMdAj_k&hl=es&fs=1&quot; type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
  • Yo se bien que estoy afuera
    Pero el dia en que yo me muera
    Se que tendras que llorar
    Llorar y llorar, llorar y llorar
    Diras que no me quisistes
    Pero vas a estar muy triste
    Y asi te vas a quedar
    Con dinero y sin dinero
    Hago siempre lo que quiero
    Y mi palabra es la ley
    No tengo trono ni reina
    Ni nadie que me comprenda
    Pero sigo siendo el rey
    Y yo sigo siendo el rey
    El rey sigo siendo yo
    Quien es el rey
    Una piedra en el camino
    Me enseño que mi destino
    Era rodar y rodar
    Rodar y rodar, rodar y rodar
    Despues me dijo un arriero
    Que no hay que llegar primero, sino hay que saber llegar
    El rey sigo siendo yo.
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/utbOJX4XmoE&hl=es&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/utbOJX4XmoE&hl=es&fs=1&quot; type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
  • Girasol escribió :
    <OBJECT height=344 width=425>
    <embed src="http://www.youtube.com/v/utbOJX4XmoE&hl=es&fs=1&quot; type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></OBJECT>
    </P>Venga va otra.
    Por la lejana montaña
    va calbalgando un jinete
    vaga solito en el mundo
    y va deseando la muerte
    Lleva en su pecho una herida
    va con su alma destrozada
    quisiere perder la vida
    y reunirse con su amada
    La quería más que a su vida
    y la perdió para siempre
    por eso lleva una herida
    por eso busca la muerte
    Con su guitarra cantando
    se pasa nocher enteras
    hombre y guitarra llorando
    a la luz de las estrellas
    Después se pierde en la noche
    y aunque la noche es muy bella
    él va pidiendole a Dios
    que se lo lleve con ella
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/iNUwoAv8VBc&hl=es&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/iNUwoAv8VBc&hl=es&fs=1&quot; type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
  • Baby IceBaby Ice MegaForero
    ¿Qué es lo que ha pasado?
    Organizando el pesimismo
  • zxplofzxplof Forero Senior ✭✭✭
    na.......las tipicas melancolias otoñales.
  • Contrabando En La Frontera:
    Cruzaron por el desierto
    para llegar a Tijuana
    en una caja de muerto
    llevaban la ****
    es una hazaña asombrosa
    pero asi eran de arriesgados
    llenaban la carroza
    con papeles arreglados
    era Rosaura Santana
    el otro Juan escalante
    la primera la texana
    el segundo traficante
    al llegar a la garita
    cansados y polvorientos
    la policia de Sonoyta
    acepto los documentos
    y llegaron a Tijuana
    todo estaba preparado
    100 kilos de ****
    pasarian al otro lado
    todos querian ver el muerto
    los policias de la aduana
    pero como no era cierto
    solo hayaron ****
    señores creo que este asunto
    a todos los tiene hundidos
    no de por vivo el muertito
    y quedaran detenidos
    y sacaron las pistolas
    y el primer gallo primero
    la gente corre echa bola
    al ver muerto al aduanero
    hubo una gran balacera
    heridos por todos lados
    quedaron en San Isidro
    14 muertos tirados
    Callo Rosaura Santana
    lo mismo que el mexicano
    les quito la ****
    el gobierno americano
  • Ya 3 veces me he salvado
    de una muerte segurita
    con puro cuerno de chivo
    me han tirado de cerquita
    118 balazos y Diosito me los quita
    La primera fue en mi casa
    me quisieron secuestrar
    pero no deje agarrarme
    Me empiezan a disparar
    fueron 28 balazos
    me dieron 1 nomas
    En la segunda ocasion
    fue saliendo de Ensenada
    me tiraron de unos carros
    2 rafagas de metralla
    60 tiros de cuerno
    3 balazos me pegaban
    jajaja aia
    y ahi le va un saludo para
    mi compa el tesoro de sinaloa
    y vamonos pa' Tijuana compare
    vamonos
    La tercera es la vencida
    dice un dicho muy mentado
    Me agarraron en Tijuana
    con 2 cuernos dispararon
    Ahi fueron 30 balazos
    pero ni uno me pegaron
    Para proteger mi vida
    Dios me acobija en sus brazos
    al tesoro no han matado
    118 balazos
    La virgen de Guadalupe
    me anda cuidando los pasos
    Adios ciudad de Tijuana
    ya no me van a mirar
    en mi Ford 79
    pasearme en el Bulevard
    ahi por la Sanchez Taguada
    la Rebo y la Cuca Paz.
  • Nunca más oíste tú hablar de mi
    En cambio yo seguí pensando en ti
    De toda esta nostalgia que quedó
    Tanto tiempo ya pasó
    Y nunca te olvidé
    Cuantas veces yo pensé volver
    Y decir que de mi amor nada cambió
    Pero mi silencio fue mayor
    Y en la distancia muero dia a dia
    Sin saberlo tú
    El resto de ese nuestro amor quedo
    Muy lejos, olvidado para ti
    Viviendo en el pasado aún estoy
    Aunque todo ya cambió
    Se que no te olvidaré
    Sin saberlo tú
    Pensé dejar de amarte de una vez
    Fue algo tan dificil para mi
    Si alguna vez, mi amor, piensas en mi
    Ten presente al recordar
    Que nunca te olvidé
    Sin saberlo tú
    Sin saberlo tú.
  • Nunca he sentido igual una derrota
    que cuando ella me dijo se acabó.
    Nunca creí tener mi vida rota
    ahora estoy solo y arrastro mi dolor.
    Y mientras en la calle está lloviendo
    una tormenta hay en mi corazón
    dame otra copa aún estoy sereno
    quiero beber hasta perder el control.
    Cuántas noches soñé que regresabas
    y en mis brazos llorabas por tu error
    luego un ruido del bar me despertaba
    y el que lloraba entonces era yo.
    Y mientras ella está con otro tipo
    mis lágrimas se mezclan con alcohol
    ella se fue porqué no me lo dijo
    y siento que mi vida fracasó.
  • RinconeteRinconete Forero Master ✭✭✭✭
    Dedicado especialmente para el principal patrocinador del amor libre entre foreros.<img src="https://us.v-cdn.net/6030826/uploads/emojis/11.gif"/&gt; <img src="https://us.v-cdn.net/6030826/uploads/emojis/11.gif"/&gt; <img src="https://us.v-cdn.net/6030826/uploads/emojis/11.gif"/&gt; <img src="https://us.v-cdn.net/6030826/uploads/emojis/11.gif"/&gt; <img src="https://us.v-cdn.net/6030826/uploads/emojis/11.gif"/&gt;
    At first, I was afraid,
    I was petrified.
    I kept thinking
    I could never live without you by my side.
    But then I spent so many nights
    Just thinking how you did me wrong.
    And I grew strong.
    I learned how to get along.
    So, now you're back
    From outer space.
    I just walked in to find you here
    Without that look upon your face.
    I should have changed that stupid lock.
    I should have made you leave your key,
    If I had known for just one second
    You'd be back to bother me.
    Oh, now go,
    Walk out the door.
    Just turn around now.
    You're not welcome anymore.
    Weren't you the one
    Who tried to break me with desire?
    Did you think I'd crumble?
    Did you think I'd lay down and die?
    Oh, no, not I.
    I will survive.
    As long as I know how to love, I know I'll be alive.
    I've got all my life to live.
    I've got all my love to give.
    I will survive.
    I will survive.
    Yeah, yeah.
    It took all the strength I had
    Just not to fall apart.
    I'm trying hard to mend the pieces
    Of my broken heart.
    And I spent so many nights
    Just feeling sorry for myself.
    I used to cry.
    But now, I hold my head up high.
    And you see me
    With somebody new.
    I'm not that stupid little person
    Still in love with you.
    And so, you thought you'd just drop by
    And you expect me to be free.
    But now I'm saving all my love
    For someone who's loving me.
    Oh, now go,
    Walk out the door.
    Weren't you the one
    Oh, no, not I.
    I will survive.
    I will survive.
    I will survive.
    Yeah, yeah.
    Que nuestra luz interior ilumine la existencia.
    "Si es posible, debe hacerse reír hasta a los muertos".
    Leonardo da Vinci
    ACUPUNTURA EN ANIMALES
