Inicio Off-Topics
Para Los Que No Entienden Lo Que Pasa
GT-ONEGT-ONE MegaForero
Ahora ya entiendo muchas cosas, este ZP
<table style="margin-left: 12.75pt; width: 461.1pt; border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0" width="615"> <tbody> <tr> <td style="border-top: 1pt solid black; border-right: 1pt solid rgb(191, 191, 191); border-bottom: 1pt solid black; padding: 0cm 3.75pt; width: 45pt;" width="60">
ANY
</td> <td style="border-top: 1pt solid black; border-right: 1pt solid rgb(191, 191, 191); border-bottom: 1pt solid black; padding: 0cm 3.75pt; width: 45pt;" width="60">
1 $ =
</td> <td style="border-top: 1pt solid black; border-right: 1pt solid rgb(191, 191, 191); border-bottom: 1pt solid black; padding: 0cm 3.75pt; width: 108pt;" width="144">
Preu del barril de petroli en dòlars
</td> <td style="border-top: 1pt solid black; border-right: 1pt solid rgb(191, 191, 191); border-bottom: 1pt solid black; padding: 0cm 3.75pt; width: 121.3pt;" width="162">
Preu del barril de petroli en euros
</td> <td style="border-top: 1pt solid black; border-right: 1pt solid black; border-bottom: 1pt solid black; padding: 0cm 3.75pt;">
Preu del litre de gasolina al sortidor
</td></tr> <tr> <td style="border-top: medium none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; padding: 0cm 3.75pt; width: 45pt;" width="60">
2000
</td> <td style="border-top: medium none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; padding: 0cm 3.75pt; width: 45pt;" width="60">
1,20 €
</td> <td style="border-top: medium none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; padding: 0cm 3.75pt; width: 108pt;" width="144">
60 $
</td> <td style="border-top: medium none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; padding: 0cm 3.75pt; width: 121.3pt;" width="162">
72,00 €
</td> <td style="border-top: medium none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; padding: 0cm 3.75pt;">
0,82 €
0,64 €
110 $
70,40 €
1,28 €
</td></tr></tbody></table>
ANY=AÑO
DOLARS=DOLARES
PREU=PRECIO
BARRILS=BARRILES
PETROLI=PETROLEO
LITRE=LITRO
SORTIDOR=SURTIDOR
FILOMENA
  • malospelosmalospelos Banned ✭✭✭✭✭
    Yo es que no entiendo catalán. No sé, no me obligaron a estudiarlo y ahora no lo sé. Oderrrr!!! qué le voy a hacer????<img src="https://us.v-cdn.net/6030826/uploads/emojis/5.gif"/&gt;
  • znkznk MegaForero ✭✭✭✭
    Pues explicame por que si el barril de petroleo cuesta algo menos que entonces (en Euros) pagamos por la gasolina mas de un 50% más.
    —¿Cómo va tu vida amorosa?
  • GT-ONEGT-ONE MegaForero
    Fijate en el valor del dolar frente al euro
    FILOMENA
    El problema es que se crece a un ritmo superior al que se produce el petroleo a nivel mundial . Luego está china....que tira tela...
    ...Ahora bien, abrir el hilo para cubrir las espaldas a zp manda pelotas.....Porque una cosa es una cosa y la otra (tema construcción por ejemplo o inmigración) es otra.
  • Hola:
    Estando el dolar mas barato que el euro, que por cierto ahora se puede hacer un viaje a USA pagando menos, porque el litro de gasolina está mas caro, pues porque han subido los impuestos al carburante desde el 2000, sino de otra forma no se entiende.
  • alexiusalexius MegaForero
    Precisamente por eso te lo preguntan, porque con una posición tan fuerte del Euro, deberíamos poder comprar más barato. Lo que no dicen los datos que has puesto es el por qué de esa subida estando el barril en euros resulta más barato. Y eso es porque no tenemos refinerías. Si nosotros compráramos barriles y refináramos nuestro combustible íntegramente, los costes de producción serían mucho más baratos, pero lo que hacemos es comprar los combustibles ya preparados para el usuario final, con el sobre coste que eso tiene. España, por no sé qué política que lleva, no permite a las petroleras españolas crear más refinerías en España, por lo que compra o produce el combustible en terceros países, con el sobre coste de la exportación, aranceles, impuestos de salida de dichos países, más el incremento de tasas por entrar en España.
    Somos muy listos, sí señor.
    Edito: aunque es verdad que China e India están creciendo en demanda, los países productores han reducido la producción por falta de demanda, ya que los países desarrollados prácticamente han trasladado el consumo de energía industrial a la energía nuclear, y los coches consumen muchísimo menos que hace 10 años. El problema, vuelvo a reiterar, es la demanda de refinado.
    Un poquito de Cultura:
    https://blogvasari.wordpress.com/
  • belmarbelmar MegaForero
    Na, la clave es que hace un año por éstas fechas el petroleo estaba a 70 dólares y la inflacción al 2.5 %.
    Ahora que el precio del petroleo se ha duplicado, pues la inflacción también.
    No hace falta estudiar economia 5 años para comprender eso...
    Carpe Diem.
