¿Qué os parecen este par de cochecillos?
fleischfleisch MegaForero ✭✭✭
Performance
Acceleration: 0-100 km/h (0–62 mph) under 3.5 seconds
Top speed: 390 km/h (240 mph)
Standing quartermile: 10 seconds, end speed 217 km/h (135 mph)
Braking distance: 32 m (100–0 km/h)
Performance
Acceleration: 0-100 km/h (0–62 mph) 3.2 seconds
Top speed: 395+ km/h (242+ mph)
Standing quartermile: 9 seconds, end speed 235 km/h (146 mph)
Braking distance: 31 m (100–0 km/h)
Lateral g-force: 1.3 g
Fuel consumption: Highway travel: 13 l/100 km
Combined: 17 l/100 km
Body
Two-door, two-seater with removable hardtop stowable under the front boot lid. The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foam sandwich reinforcements.
spacer.gifspacer.gifspacer.gifBody
Dimensions
Ground clearance: 100 mm (3.9 inch)
Fuel capacity: 80 litres (17.6 gallons)
Luggage compartment: 120 litres (26.4 gallons)
Dry weight: 1175 kg
spacer.gifspacer.gifspacer.gifDimensions
Dry weight: 1180 kg
Areodynamics
Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis. Venturi tunnels at the rear of chassis/body.
spacer.gifspacer.gifspacer.gifAreodynamics
Chassis
Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.
Front and rear suspension: Double wishbones, adjustable Öhlins Racing gas-hydraulic shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
spacer.gifspacer.gifspacer.gifChassis
Front and rear suspension: Double wishbones, adjustable VPS custom racing shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
Brakes
Front brakes: Ventilated discs Ø 340 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
Rear brakes: Ventilated discs Ø 315 mm, 28 mm wide. 4 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
spacer.gifspacer.gifspacer.gifBrakes
Front brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
Rear brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
Wheels
Koenigsegg magnesium alloy wheels with centre locking.
Front: 18” x 9,0”.
Rear: 20” x 12,5”.
spacer.gifspacer.gifspacer.gifWheels
Front: 19” x 9.5”
Rear: 20” x 12.5”
Tyres
Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.
Front: 255/40 ZR 18
Rear: 335/30 ZR 20
spacer.gifspacer.gifspacer.gifTyres
Front: 255/35–19” (Y)
Rear: 335/30–20” (Y)
Steering
Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres.
spacer.gifspacer.gifspacer.gifSteering
Engine
Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
Displacement: 4.700 cm3.
Compression: 8.6:1
Weight: 210 kg
Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
Oil: SAE 10W60 fully synthetic racing.
Oil tank capacity: 12 litres (2.64 gallons)
Induction system: Sequential, multipoint fuel injection. Supercharging with 1.0 bar boost pressure. Intercooler.
Fuel: 98 RON unleaded.
Ignition system: Direct coil on plug. Transistorised.
Power output: 655 bhp at 6.800 rpm.
Maximum torque: 750 Nm (550 ftlb) at 5.000 rpm.
Maximum rpm: 7.300 rpm.
spacer.gifspacer.gifspacer.gifEngine (click for more info about the CCR engineering specifics)
Compression: 8.6:1
Weight: 215 kg
Induction system: Sequential, multipoint fuel injection. Dual Rotrex centrifugal compressors with 1.4 max boost pressure. Intercooler.
Power output: 806 bhp at 6.900 rpm.
Maximum torque: 920 Nm (678 ftlb) at 5.700 rpm.
Maximum rpm: 7.600 rpm.
Transmission
Specially developed 6-speed gearbox by Cima. Incorporated internal oil pump and oil cooler. Torque sensitive, limited slip differential.
Clutch: Dual Plate, organic or cintered Ø 215 mm (8.46 inch).
spacer.gifspacer.gifspacer.gifTransmission
Clutch: Dual Plate, organic or cintered Ø 215 mm (8.46 inch). Oil-cooled and electronically operated.
Equipment
In standard mode the car is very well equipped with many items that competitors have as options. Many customers, however, want to further equip the car. Therefore we can offer a list of customer options which should fulfil every demand.
Standard equipment
dot_grey.gif Removable roof panel
dot_grey.gif Climate control
dot_grey.gif Electric rear mirrors
dot_grey.gif Leather interior
dot_grey.gif Central locking
dot_grey.gif Electrical windows
dot_grey.gif Alarm with immobilizer
dot_grey.gif Toolkit
dot_grey.gif Driver side airbag
dot_grey.gif Power steering
dot_grey.gif Hydraulic ride height control
dot_grey.gif Servo assisted brakes
dot_grey.gif ABS
dot_grey.gif Traction control
dot_grey.gif Stereo with CD-player
Customer options
dot_grey.gif Custom Color Leather Interior
dot_grey.gif Custom Paint Color
dot_grey.gif Parking Sensors
dot_grey.gif GPS Navigation
dot_grey.gif Sequentially operated gearbox
dot_grey.gif Rearview Camera
dot_grey.gif Fitted Luggage
Koenigsegg reserves the right to change or amend this information without notice.
spacer.gifspacer.gifspacer.gifEquipment
Standard equipment
dot_grey.gif Aluminium rear light casings
dot_grey.gif Detachable roof panel
dot_grey.gif Electric rear view mirrors
dot_grey.gif ABS
dot_grey.gif Tyre pressure sensors
dot_grey.gif Car cover
Customer options
Copyright © Koenigsegg Automotive AB 1994-2004. [email protected] Tel: +46 431 45 44 60Hosted by FS DataProduced by Treehouse
  • ivanlb1ivanlb1 Forero Master ✭✭✭✭
    pos mu bonitos!y sobretodo rapidos!jeje!
    me quedo con el de la derecha!
  • Javier.netJavier.net MegaForero ✭✭✭
    ¡Vaya pedazo de bestias! nunca había oido hablar de estos coches.
  • maiksportbackmaiksportback MegaForero
    ba nada, los veo todo los dias en mi garaje...image
  • FerbeFerbe MegaForero ✭✭✭✭✭
    Muy bonitos, y muy rapidos!!
    PD: Una vez salio en el telediario una marca de coches que poseia las iniciales de cada miembro que la compone. Son unos tios que tienen un taller y hacen coches artesanales, parecidos a estos, y en España hay 3 o 4 circulando. ¿Alguien sabe que marca es?
  • temhmednettemhmednet Forero Senior ✭✭✭
    Bah, esos no son rapidos, este si es rapido.
    Coge algo mas de 800Km a la hora y en salida en mas rapido que la bascula del baño que tengo en casa.
    Que yo sepa, la fabrica o taller donde se construyen esta o estaba en la provincia de Murcia, creo recordar que era Cartagena u otro pueblo de Murcia.
    Si, creo que si es en Cartagena...
  • FluenceFluence Forero Master
    IM-PRESIONANTES!!!!!!
    Un saludo. Fluence
    ATCUALMENTE:
    A mí me gustaría saber el precio de un bicharraco de estos, por si un día me hago político, saber en que invertir lo que trinque... image
    si eso parece un transformer chico jajajaja
    Lui21 escribió :
    de pequeño yo los coches los mantaba igual........techdata_cc8s_sideopen.jpg
  • carodgacarodga MegaForero ✭✭✭✭✭
    VAYA 2 SÚPERPEPINOS, me gustaría ver alguna prueba de este par...
    Un blog independiente, donde intentaremos transmitiros algo de la pasión que compartimos todos...
    https://www.uvedoce.com/
  • fran83fran83 MegaForero ✭✭✭
    Que preciosidad de coches, y no el 1007 image
