fallo cuadro scenic
<!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Arial","sans-serif"; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-fareast-language:EN-US;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:12.0pt; mso-ansi-font-size:12.0pt; mso-bidi-font-size:12.0pt; mso-ascii-font-family:Arial; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Arial; mso-bidi-font-family:Arial; mso-fareast-language:EN-US;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:595.3pt 841.9pt; margin:70.85pt 3.0cm 70.85pt 3.0cm; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]> > /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} </style> <![endif]--> Un saludo a [email protected],soy novato en el foro,y empiezo con un “problemilla” que tengo con mi “renol”scenic (aquí creo que lo escribis así),se trata del cuadro,sé queda todo negro por momentos,el coche funciona normalmente,luces,limpias,intermitentes,etc,ló llevé al concesionario y me dijeron que tenían que cambiarlo,osea,700 euros del ala,el coche tiene cuatro años y 58000km,llamé a renol España y ni caso, buscando por los foros me encontré con cuatro personas con el mismo problema,quisiera saber si por estos lares hay alguien ó conoce a alguien con el mismo problema,me vale también que me acompañéis en el sentimiento,gracias de antemano.
«13
  • Maniolo_bravitaManiolo_bravita Forero Senior ✭✭✭
    Te acompaño en el sentimiento y te doy la BIENVENIDA al foro.<img src="https://us.v-cdn.net/6030826/uploads/emojis/5.gif"/&gt;
    ¿Has mirado por desguaces? Si tienes suerte te puedes ahorrar unos buenos €.
    De todas formas, 700€ para un cuadro, es mucho dinero.
    Es que estos cuadros modernos multifunciones son mas que unas agujitas como en los clasicos, incorporan muchisima electronica y piden por ellos igual que por las centralitas y demas...
    Normalmente no tienen reparacion y hay que pasar por la piedra... digo normalmente porque a lo mejor algun electronico podria mirarlo, pero al ser microprocesadores especificos de la marca....
  • spiq-espiq-e MegaForero
    una putada, ahora tienen la mania de meter modulos electronicos para todo.... y despues pasa lo que pasa......
  • scenic 2.016vscenic 2.016v Forero Senior ✭✭✭
    llama a renault a atencion al cliente, si los camelas bien, les sacaras algo de dinerito para ese cuadro roto.
    "no es mas rico quien mas tiene, sino quien menos necesita"
    "Si lo que vas a decir no es más bello que el silencio: no lo digas"
    No te sorprendas, esos cuadros fallan muchisimo.
    Al menos el tuyo no ha ardido, que se de mas de uno que ha empezado a echar humo por dentro.
    Como bien te han dicho vale mas o menos eso...ami me dijeron 600euros.
    Arreglo suelen tener, muchas veces la cosa es muy sencilla, simplemente soldando un poco "dejan de hacer tonterias" pero en la casa no arreglan nada, simplemente pieza nueva.
    No creo que fuera para el R5 no?<img src="https://us.v-cdn.net/6030826/uploads/emojis/11.gif"/&gt; <img src="https://us.v-cdn.net/6030826/uploads/emojis/11.gif"/&gt; <img src="https://us.v-cdn.net/6030826/uploads/emojis/11.gif"/&gt;
    No ****, pero yo sino toy trabajando o estoy durmiendo o estoy en los talleres<img src="https://us.v-cdn.net/6030826/uploads/emojis/4.gif"/&gt;
    Asi que estoy enterado de bastantes cosas.
  • justisieirojustisieiro Forero Junior
    Saludos a todos,mé lo desmontó un colega electronico, y ló resoldó,pero no hay manera,sé sigue encendiendo y apagando y cada vez mé suma más kilometros a ló loco,hoy mismo hé tefoneado a 83(nó es broma) desguaces en toda galicia y hasta uno de sevilla que me dió la central de desguaces, y nada,no ló hay, en algunos me dijeron que está solicitadisimo,que hay mucha demanda,volví a llamar a renault españa y<img src="https://us.v-cdn.net/6030826/uploads/emojis/114.gif"/&gt; (me daré una vuelta por consumidores) así que nada a pasar por el aro.
  • sebitasebita Forero Junior
    Fallo Cuadro Scenic, Se Puede Reparar
    hola mi nombre es sebas y puedo reparar el fallo del cuadro scenic II mi correo es [email protected]
  • nolotuningnolotuning Forero Junior
    sobre cuanto saldra la reparacion
  • toni montadatoni montada Forero Junior
    nunca comprare un renault
    vaya castañas de coches, son de lejos los peores coches de hoy en dia. entre las marcas mas reconocidas claro...
    una opinion basada en experiencias claramente constrastadas y amplios estudios de mercado y de satisfacion del cliente....
    Lamentablemente Renault sigue siendo lider de ventas año tras año...
    Y cuando pasas por los talleres oficiales de cualquier marca, esta tambien lleno de coches de su propia marca.... basandonos en eso,,, no hay coche bueno!!! <img src="https://us.v-cdn.net/6030826/uploads/emojis/11.gif"/&gt;
    Saludos a [email protected],soy el del dichoso cuadro,hombre, fué una putada,pero la verdad,es el unico problema que he tenido con el scenic(5 años y 2meses)y eso que soy un abandonao pal coche.<img src="https://us.v-cdn.net/6030826/uploads/emojis/21.gif"/&gt;
    Por cierto, sebas no me has devuelto el correo<img src="https://us.v-cdn.net/6030826/uploads/emojis/61.gif"/&gt;
    solo respondo en mi email
    para cualquier consulta respecto a la reparacion en mi email gracias, pero te adelanto que sale en 200€ saludos sebas
  • rverirveri Forero Junior
    Scenic,cuadro de mandos
    Lo de Renault es vergonzoso. Mi Senic es del 2004, 85000 km, el mismo problema del cuadro y no dicen nada de reparaciones, saben perfectamente que se debe a un fallo de fabricación y se lo pasan por el forro.
    Con este comportamiento tan miseranle, desde luego para mí Renault se acabó
  • jordi 1964jordi 1964 Forero Junior
    El cuadro como dice el amigo no solo es soldar un par de piezas se tiene q bobinar una pieza q esta debajo de cuadro y soldar un par de piezas para q no te pase, mi amigo o hace por 250e., esta en barcelona
    justisieiro escribió : »
    saludos a todos,mé lo desmontó un colega electronico, y ló resoldó,pero no hay manera,sé sigue encendiendo y apagando y cada vez mé suma más kilometros a ló loco,hoy mismo hé tefoneado a 83(nó es broma) desguaces en toda galicia y hasta uno de sevilla que me dió la central de desguaces, y nada,no ló hay, en algunos me dijeron que está solicitadisimo,que hay mucha demanda,volví a llamar a renault españa y<img src="https://us.v-cdn.net/6030826/uploads/emojis/114.gif"/&gt; (me daré una vuelta por consumidores) así que nada a pasar por el aro.
    Cuadro mandos scenic
    En bacrelona ay unos chicos q te lo arreglan por 250€ y la verdad q muy bien el tel es 669790223
  • JBBJBB Forero Junior
    El negocio de Renault con los cuadros de la Scenic
    Quiero denunciar en este foro que en Renault España son unos miserables por tener montado un negocio redondo con los cuadros de instrumentos y no reconocer que se trata de un fallo común que deberían de subsanar gratuitamente por ser vicio oculto a todos los clientes que tengan una Scenic II. Entre el 4 y 5 año se te apaga el cuadro (no es ninguna avería de fusibles) y la única solución que te dan es sustituirlo por uno nuevo (unos 800€) aunque saben por los cientos de personas que hemos reclamado que tienen un problema de sobrecalentamiento que se puede reparar. Es una pena que no nos juntemos para denunciar conjuntamente todos los afectados pues lograriamos mas presión. Para mi Renault se ha acabado, su política de postventa ante fallos de este tipo es miserable.
  • ospanacarospanacar Forero Junior
    Problemas con el cuadro de mando Scenic
    Hola
    Yo tengo ese mismo problema. Hoy al ir a coger el coche, el cuadro de mando completamente apagado. Ya está en el taller y lo mismo que a ti 700€ del ala. Llamo A Atención al cliente y me dicen que la averia tengo que pagarla yo, que el coche ya tiene 6 años.
    Pese a que les comunico que he visto por un montón de foros que este fallo es bastante común.
    Les he comentado que pienso hacer una campaña para conseguir realizar una reclamación conjunta.
    Si alguien tiene el mismo problema que me escriba [email protected]
    A ver si entre todos desmantelamos a la poderosa e intocable Renault.
    Por cierto, yo ya tuve varios problemas, entre ellos se me cayeron las lunas del coche, climatizador, airbag...
